Disables PIM on a router interface.
| ipv4 | Specifies the IPv4 address family. |
| delete | Specifies to delete PIM on a VLAN. |
| tunnel | Specifies the tunnel name. |
| tunnel_name | Specifies to configure PIM information for interface. |
| all | Specifies to configure PIM information on all Layer 3 interfaces. |
N/A.
Use this command to disable PIM for a specific or all tunnels.
The following example disables PIM on tunnel accounting:
configure pim delete tunnel accounting
This command was first available in ExtremeXOS 32.3.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the PIM feature, see the Switch Engine v33.1.1 Licensing Guide document.
